Salta al contenuto principale
IBM ThinkPad 600E Hard Drive Disk Replacement
Cosa ti serve
  1. IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, immagine 1 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, immagine 2 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 2, immagine 1 di 1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, immagine 1 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, immagine 2 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, immagine 3 di 3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Hard Drive Disk Replacement, Hard Drive Disk: passo 4, immagine 1 di 1
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, immagine 1 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, immagine 2 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, immagine 3 di 3
    • Using a coin, remove the coin screw by turning counterclockwise.
    • It's best to use a thicker coin, such as a nickel.
  6. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 6, immagine 1 di 1
    • Using a plastic spudger, pry off the plastic cover by pulling it out.
  7. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, immagine 1 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, immagine 2 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, immagine 3 di 3
    • Utilizing your fingers, untuck the tab and pull to remove the hard drive.
  8. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, immagine 1 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, immagine 2 di 3 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, immagine 3 di 3
    • Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
    • four 3mm PH0 screws
    • The metal bracket is still attached with a weak adhesive tape, gently pry it off with a spudger.
  9. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 9, immagine 1 di 2 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 9, immagine 2 di 2
    • The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-4, Nance Fall 2016 Membro di USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 54
Tutti i Tempi: 3,127
