Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  3. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  4. Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  5. Remove the four Phillips head screws.
    • Remove the four Phillips head screws.
  6. Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  7. Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop. The connector is very fragile, so be careful.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
Conclusione
Altre 2 persone hanno completato questa guida.
John Allande
Membro da: 15/04/2010
64 Reputazione
1 Guida realizzata
Cal Poly, Team 26-27, Regan Spring 2010 Membro di Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,601
