Salta al contenuto principale
IBM ThinkPad 560z Keyboard Replacement
Cosa ti serve
  1. IBM ThinkPad 560z Keyboard Replacement, Upper Case: passo 1, immagine 1 di 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Replacement: passo 2, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement: passo 2, immagine 2 di 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Replacement: passo 3, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement: passo 3, immagine 2 di 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Replacement: passo 4, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement: passo 4, immagine 2 di 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Replacement: passo 5, immagine 1 di 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Replacement: passo 6, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement: passo 6, immagine 2 di 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Replacement: passo 7, immagine 1 di 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Replacement: passo 8, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement: passo 8, immagine 2 di 2
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: passo 9, immagine 1 di 2 IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: passo 9, immagine 2 di 2
    • Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
Conclusione
Cal Poly, Team 26-27, Regan Spring 2010 Membro di Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,417
