Salta al contenuto principale
Hytera TC-580 Speaker Replacement
Cosa ti serve
  1. Hytera TC-580 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Hytera TC-580 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: passo 2, immagine 1 di 2 Hytera TC-580 Speaker Replacement: passo 2, immagine 2 di 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: passo 3, immagine 1 di 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: passo 4, immagine 1 di 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: passo 8, immagine 1 di 2 Hytera TC-580 Speaker Replacement: passo 8, immagine 2 di 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: passo 9, immagine 1 di 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: passo 10, immagine 1 di 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: passo 11, immagine 1 di 3 Hytera TC-580 Speaker Replacement, Speaker: passo 11, immagine 2 di 3 Hytera TC-580 Speaker Replacement, Speaker: passo 11, immagine 3 di 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: passo 12, immagine 1 di 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Conclusione
Mohammed Chehab
Membro da: 02/14/18
88 Reputazione
1 Guida realizzata
USF Tampa, Team S3-G4, Nance Spring 2018 Membro di USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 495
