Salta al contenuto principale
HyperX QuadCast S Pop Filter Replacement
  1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, immagine 1 di 3 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, immagine 2 di 3 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: passo 1, immagine 3 di 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Pop Filter Replacement: passo 2, immagine 1 di 3 HyperX QuadCast S Pop Filter Replacement: passo 2, immagine 2 di 3 HyperX QuadCast S Pop Filter Replacement: passo 2, immagine 3 di 3
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
  3. HyperX QuadCast S Pop Filter Replacement: passo 3, immagine 1 di 3 HyperX QuadCast S Pop Filter Replacement: passo 3, immagine 2 di 3 HyperX QuadCast S Pop Filter Replacement: passo 3, immagine 3 di 3
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
  4. HyperX QuadCast S Pop Filter Replacement, Pop Filter: passo 4, immagine 1 di 1
    • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
    • The pop filter is just the grey foam surrounding the inside of the microphone.
  5. HyperX QuadCast S Pop Filter Replacement: passo 5, immagine 1 di 1
    • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
    • When you replace the pop filter, remember that you will need to glue it back into place as before.
  6. HyperX QuadCast S Pop Filter Replacement: passo 6, immagine 1 di 2 HyperX QuadCast S Pop Filter Replacement: passo 6, immagine 2 di 2
    • Reach into the microphone and remove the pop filter.
Conclusione
Un commento
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 120
Tutti i Tempi: 1,919
