Salta al contenuto principale
HyperX QuadCast S Polar Pattern Knob Replacement
  1. HyperX QuadCast S Polar Pattern Knob Replacement, Polar Pattern Knob: passo 1, immagine 1 di 1
    • Place the microphone down on a flat surface.
    • Orientate the microphone so that the back is facing toward you.
  2. HyperX QuadCast S Polar Pattern Knob Replacement: passo 2, immagine 1 di 1
    • You will see a knob illustrated with four symbols, representing different polar pattern modes.
    • The polar pattern knob is indicated in the circle.
  3. HyperX QuadCast S Polar Pattern Knob Replacement: passo 3, immagine 1 di 3 HyperX QuadCast S Polar Pattern Knob Replacement: passo 3, immagine 2 di 3 HyperX QuadCast S Polar Pattern Knob Replacement: passo 3, immagine 3 di 3
    • Using your hand, apply force to pull and remove the knob from the microphone.
    • It's essential to keep in mind that this knob will come out quickly, do not pull too hard to ensure nothing is damaged.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 566
