Salta al contenuto principale
HyperX QuadCast S Gain Control Knob Replacement
  1. HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: passo 1, immagine 1 di 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: passo 1, immagine 2 di 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: passo 1, immagine 3 di 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Gain Control Knob Replacement: passo 2, immagine 1 di 3 HyperX QuadCast S Gain Control Knob Replacement: passo 2, immagine 2 di 3 HyperX QuadCast S Gain Control Knob Replacement: passo 2, immagine 3 di 3
    • Orientate the microphone with the gain control knob upwards.
    • Pull outwards from the microphone to release the gain control knob.
    • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
  3. HyperX QuadCast S Gain Control Knob Replacement: passo 3, immagine 1 di 3 HyperX QuadCast S Gain Control Knob Replacement: passo 3, immagine 2 di 3 HyperX QuadCast S Gain Control Knob Replacement: passo 3, immagine 3 di 3
    • Remove the gain control knob.
    • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 71
Tutti i Tempi: 986
