Salta al contenuto principale
Hydration Pack Bladder Hose Bite Valve Replacement
Cosa ti serve
  1. Hydration Pack Bladder Hose Bite Valve Replacement, Find an appropriately-sized replacement valve: passo 1, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Find an appropriately-sized replacement valve: passo 1, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Find an appropriately-sized replacement valve: passo 1, immagine 3 di 3
    • Find the same brand part of your valve for sale online or find one with the same size as it.
    • You may measure the inside and outside diameter of the hose to ensure that the valve will fit. I will be using a ruler for this.
    • I first measured the new bite valve.
    • Then, I measured the old bite valve. Their sizes seemed similar enough. Finally, I compared the two bite valves and concluded that the new bite valve would be a suitable replacement.
    Chiedi a FixBot
  2. Hydration Pack Bladder Hose Bite Valve Replacement, Remove the old valve: passo 2, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Remove the old valve: passo 2, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Remove the old valve: passo 2, immagine 3 di 3
    • Remove the old or broken part by pulling it off if it's loose enough.
    • Putting the bite valve with the portion of the hose in a bowl of boiling water could make it easier to pull the bite valve off.
    • I made sure to keep the bite valve and the part of the hose around it submerged in the boiling water.
    • If pulling it off is not possible, get your scissors or razor blade. I will be using the former, as shown in the third image.
    • Ensure the end of the hose is cut at a 90-degree angle to avoid cutting yourself. Make sure your hand is far from the scissors while keeping a stable grip.
    • Once you're certain that nothing else is in the way of the scissors, make the cut.
    Chiedi a FixBot
  3. Hydration Pack Bladder Hose Bite Valve Replacement, Wash the parts: passo 3, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Wash the parts: passo 3, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Wash the parts: passo 3, immagine 3 di 3
    • Use mild soap and water to clean the outside of the tube. Swirl the water with your hands to mix the soap and water well.
    • The method I used was to soak it in a bowl of hot soapy water for 5 - 10 minutes before rinsing it, which will clean the outside and inside of the tube. This will let you skip the next step. However, this requires a big enough bowl to fit the hose.
    Chiedi a FixBot
  4. Hydration Pack Bladder Hose Bite Valve Replacement, Wash the parts: passo 4, immagine 1 di 2 Hydration Pack Bladder Hose Bite Valve Replacement, Wash the parts: passo 4, immagine 2 di 2
    • To clean the inside of the hose, head to a sink and run hot soapy water through it. Then, run regular water through it as rinsing.
    Chiedi a FixBot
  5. Hydration Pack Bladder Hose Bite Valve Replacement, Dry the parts before assembly: passo 5, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Dry the parts before assembly: passo 5, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Dry the parts before assembly: passo 5, immagine 3 di 3
    • Clean and dry the new bite valve, inside and out. I reused the hot soapy water bowl from Step 3 to do it. Rinse it after. Make sure everything is dry before moving onto the next step.
    • Depending on how new that mouth piece is, you might need to clean it. As you see here, I used the soapy water bowl to do that.
    Chiedi a FixBot
  6. Hydration Pack Bladder Hose Bite Valve Replacement, Attach the new bite valve: passo 6, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Attach the new bite valve: passo 6, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Attach the new bite valve: passo 6, immagine 3 di 3
    • Attach the new mouth piece to the new bite valve.
    • Mine had a little hole to open up while pushing the bite valve through it.
    Chiedi a FixBot
  7. Hydration Pack Bladder Hose Bite Valve Replacement, Heat the tubing, if needed: passo 7, immagine 1 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Heat the tubing, if needed: passo 7, immagine 2 di 3 Hydration Pack Bladder Hose Bite Valve Replacement, Heat the tubing, if needed: passo 7, immagine 3 di 3
    • Attach the new bite valve to the hose.
    • If you’re having trouble attaching it, you can use a lighter to heat the tube and make it pliable. Watch carefully and don’t melt it. I did this step at the sink just in case I needed water for an accident.
    Chiedi a FixBot
Conclusione
Your Bladder Hose is now ready to be used once again. Attach it back to your Hydration Pack and you're good to go.
Tony Lau
Membro da: 03/11/24
145 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 53
Tutti i Tempi: 683
