Salta al contenuto principale
Husqvarna FE 350 Rear Sprocket Replacement
Cosa ti serve
  1. Husqvarna FE 350 Rear Sprocket Replacement, Rear Sprocket: passo 1, immagine 1 di 1
    • Place the motorcycle on a stand so that the rear tire is off the ground.
  2. Husqvarna FE 350 Rear Sprocket Replacement: passo 2, immagine 1 di 2 Husqvarna FE 350 Rear Sprocket Replacement: passo 2, immagine 2 di 2
    • Use the 27mm wrench to unscrew the nut that holds the axle together. This nut is located on the right side of the motorcycle at the end of the swing-arm.
  3. Husqvarna FE 350 Rear Sprocket Replacement: passo 3, immagine 1 di 3 Husqvarna FE 350 Rear Sprocket Replacement: passo 3, immagine 2 di 3 Husqvarna FE 350 Rear Sprocket Replacement: passo 3, immagine 3 di 3
    • Move to the left side of the motorcycle and remove the axle by pulling it directly out.
    • Move back to the right side and remove the spacer shown in the third picture to ensure that is does not get lost.
  4. Husqvarna FE 350 Rear Sprocket Replacement: passo 4, immagine 1 di 2 Husqvarna FE 350 Rear Sprocket Replacement: passo 4, immagine 2 di 2
    • Pull up and back on the chain to free the tire.
  5. Husqvarna FE 350 Rear Sprocket Replacement: passo 5, immagine 1 di 1
    • Lay the tire on a flat surface with with sprocket facing up.
    • Use the 6mm Torx wrench to unscrew the six bolts holding the sprocket on.
    • Replace the sprocket and screw the bolts back in.
  6. Husqvarna FE 350 Rear Sprocket Replacement: passo 6, immagine 1 di 1
    • Be careful that the brake rotor fits in between the brake pads on the caliper.
  7. Husqvarna FE 350 Rear Sprocket Replacement: passo 7, immagine 1 di 1
    • Put the chain back on. Start at the bottom and work the chain carefully over the top of the new sprocket.
  8. Husqvarna FE 350 Rear Sprocket Replacement: passo 8, immagine 1 di 3 Husqvarna FE 350 Rear Sprocket Replacement: passo 8, immagine 2 di 3 Husqvarna FE 350 Rear Sprocket Replacement: passo 8, immagine 3 di 3
    • Push the axle back through the swing arm and the wheel.
    • Place the spacer back onto the axle with the square side pointing forward.
    • Thread the 27mm nut back onto the axle.
  9. Husqvarna FE 350 Rear Sprocket Replacement: passo 9, immagine 1 di 1
    • Use the 27mm wrench to tighten the nut down.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Un commento
C'est bien. je veux apprendre à réparer les motos
Enoch DEMBELE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 75
Tutti i Tempi: 1,191
