Salta al contenuto principale
Huntington GA41PS-RDS Acoustic Guitar String Replacement
Cosa ti serve
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: passo 1, immagine 1 di 1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, immagine 1 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, immagine 2 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, immagine 3 di 3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 3, immagine 1 di 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 3, immagine 2 di 2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, immagine 1 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, immagine 2 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, immagine 3 di 3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, immagine 1 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, immagine 2 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, immagine 3 di 3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, immagine 1 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, immagine 2 di 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, immagine 3 di 3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 7, immagine 1 di 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 7, immagine 2 di 2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
Conclusione
Ruhail Khan
Membro da: 01/18/22
145 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 738
