Salta al contenuto principale
Huffy Kids Tricycle Seat Replacement
Cosa ti serve
  1. Huffy Kids Tricycle Seat Replacement, Seat: passo 1, immagine 1 di 2 Huffy Kids Tricycle Seat Replacement, Seat: passo 1, immagine 2 di 2
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: passo 2, immagine 1 di 2 Huffy Kids Tricycle Seat Replacement: passo 2, immagine 2 di 2
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: passo 3, immagine 1 di 3 Huffy Kids Tricycle Seat Replacement: passo 3, immagine 2 di 3 Huffy Kids Tricycle Seat Replacement: passo 3, immagine 3 di 3
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: passo 4, immagine 1 di 3 Huffy Kids Tricycle Seat Replacement: passo 4, immagine 2 di 3 Huffy Kids Tricycle Seat Replacement: passo 4, immagine 3 di 3
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: passo 5, immagine 1 di 3 Huffy Kids Tricycle Seat Replacement: passo 5, immagine 2 di 3 Huffy Kids Tricycle Seat Replacement: passo 5, immagine 3 di 3
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: passo 6, immagine 1 di 2 Huffy Kids Tricycle Seat Replacement: passo 6, immagine 2 di 2
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
Conclusione
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 601
