Cosa ti serve
Take off the back covering of the phone along with the battery and SIM card.
The SIM card is located above the battery.
To remove front case from the motherboard, first pull back the silver tab (highlighted in blue) and the orange tab (highlighted in red).
For reassembly:
Place the new motherboard on the front case.
Snap the tabs back into place.
Replace back casing and snap in place.
Screw in screws.
Note: you can also follow these steps in reverse, which is the same process as outline above.
Note: replacing the power and volume buttons may be tricky. For ease, use tweezers.
You have now successfully replaced the screen for the phone.
Altre 5 persone hanno completato questa guida.
