Salta al contenuto principale
Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
Cosa ti serve
Panoramica Video
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: passo 1, immagine 1 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: passo 1, immagine 2 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: passo 1, immagine 3 di 3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: passo 2, immagine 1 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: passo 2, immagine 2 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: passo 2, immagine 3 di 3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: passo 3, immagine 1 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: passo 3, immagine 2 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: passo 3, immagine 3 di 3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: passo 4, immagine 1 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: passo 4, immagine 2 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: passo 4, immagine 3 di 3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: passo 5, immagine 1 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: passo 5, immagine 2 di 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: passo 5, immagine 3 di 3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
Conclusione
Altre 11 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.466 Guide realizzate
Un commento
Can i get video guide
filmon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 94
Tutti i Tempi: 6,626
