Salta al contenuto principale
Huawei Y300 SIM Card Replacement
Cosa ti serve
  1. Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, immagine 1 di 3 Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, immagine 2 di 3 Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
  2. Huawei Y300 SIM Card Replacement: passo 2, immagine 1 di 1
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: passo 3, immagine 1 di 1
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Huawei Y300 SIM Card Replacement, SIM Card: passo 4, immagine 1 di 1
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
Conclusione
Altre 5 persone hanno completato questa guida.
Anthony Ng
Membro da: 10/19/14
1.433 Reputazione
2 Guide realizzate
Un commento
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,756
