Salta al contenuto principale
Huawei Watch Jewel Strap Replacement
Cosa ti serve
  1. Huawei Watch Jewel Strap Replacement, Strap: passo 1, immagine 1 di 2 Huawei Watch Jewel Strap Replacement, Strap: passo 1, immagine 2 di 2
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Strap Replacement: passo 2, immagine 1 di 2 Huawei Watch Jewel Strap Replacement: passo 2, immagine 2 di 2
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Strap Replacement: passo 3, immagine 1 di 3 Huawei Watch Jewel Strap Replacement: passo 3, immagine 2 di 3 Huawei Watch Jewel Strap Replacement: passo 3, immagine 3 di 3
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Strap Replacement: passo 4, immagine 1 di 1
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Strap Replacement: passo 5, immagine 1 di 2 Huawei Watch Jewel Strap Replacement: passo 5, immagine 2 di 2
    • Repeat step 3, this time using the other strap.
Conclusione
USF Tampa, Team 5-3, Passmore Spring 2017 Membro di USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 822
