Introduzione
Use this guide if your Huawei Union’s speaker will not play sound while watching videos or listening to music.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the thirteen 3mm Phillips #00 screws from the back panel.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  5. Use the flat end of a spudger to pry off the back panel.
    • Use the flat end of a spudger to pry off the back panel.
  6. Use the flat end of a spudger to lift the speaker out of the frame and remove.
    • Use the flat end of a spudger to lift the speaker out of the frame and remove.
Conclusione
Brittany Achor
Membro da: 14/02/2018
651 Reputazione
6 Guide realizzate
USF Tampa, Team S1-G1, Nance Spring 2018 Membro di USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 60
