Salta al contenuto principale
Huawei Phone p7 Back Cover Replacement
Cosa ti serve
  1. Huawei Phone p7 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Heat to melt the adhesive sticker under the back cover.
  2. Huawei Phone p7 Back Cover Replacement: passo 2, immagine 1 di 1
    • Place the suction cup and pull to open a gap between the back cover and the body.And then insert into the guitar pick and slide to cut the sticker.
    • Attention: Be careful with the bottom side because there is the battery flex cable.
  3. Huawei Phone p7 Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
  4. Huawei Phone p7 Back Cover Replacement: passo 4, immagine 1 di 1
    • And you can replace with the new back cover.
Conclusione
Altre 10 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.822 Reputazione
62 Guide realizzate
Un commento
Is the nfc sensor in the back plate, because i broke the glass and i can see some antennas through the holes. And i think the exposure killed my nfc.
Yoran - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 11,545
