Salta al contenuto principale
Huawei P9 Charging Board Replacement
Cosa ti serve
  1. Huawei P9 Charging Board Replacement, Back Cover: passo 1, immagine 1 di 3 Huawei P9 Charging Board Replacement, Back Cover: passo 1, immagine 2 di 3 Huawei P9 Charging Board Replacement, Back Cover: passo 1, immagine 3 di 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: passo 2, immagine 1 di 2 Huawei P9 Charging Board Replacement: passo 2, immagine 2 di 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: passo 3, immagine 1 di 2 Huawei P9 Charging Board Replacement, Fingerprint sensor: passo 3, immagine 2 di 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: passo 4, immagine 1 di 3 Huawei P9 Charging Board Replacement, lower section: passo 4, immagine 2 di 3 Huawei P9 Charging Board Replacement, lower section: passo 4, immagine 3 di 3
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: passo 5, immagine 1 di 3 Huawei P9 Charging Board Replacement: passo 5, immagine 2 di 3 Huawei P9 Charging Board Replacement: passo 5, immagine 3 di 3
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: passo 6, immagine 1 di 1
    • Now you can easily remove the charging board.
Conclusione
Altre 8 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.816 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 7,133
