Introduzione
This guide will show you how to remove the Front and Rear Cameras for the Huawei P8 Lite.
Cosa ti serve
Using the Spudger, begin by removing both of the SIM slots from the side of the device.
Then remove the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Altre 3 persone hanno completato questa guida.
