Introduzione
This guide will help you replace the battery inside your Huawei P8 Lite phone.
Cosa ti serve
Begin by removing the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Continue by removing the SIM and SD card trays on the side of the device.
Locate the adhesive strip underneath the battery. Gently pull on the strip to loosen it enough to remove the battery from the device.
Altre 2 persone hanno completato questa guida.
