Introduzione
This guide has been replaced by an iFixit created guide found here.
This guide will instruct step-by-step how to disassemble the P8 Lite and replace the battery. A breakdown kit and a replacement battery will be required. Review the device Teardown Guide to get started.
Cosa ti serve
Panoramica Video
Attrezzo utilizzato in questo passaggio:Spudger$2.99
Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
Locate adhesive strip underneath the battery and grip with your thumb and forefinger. Slowly pull on the adhesive strip until it's off to release adhesive securing battery.
Insert the Spudger tool underneath the battery multiple times to separate the adhesive securing the battery. Be careful not to bend the battery and lift it from the phone frame.
To reassemble your device, follow these steps in reverse order.
Altre 6 persone hanno completato questa guida.
