Salta al contenuto principale
Huawei P20 Pro Rear Camera Lens Replacement
  1. Huawei P20 Pro Rear Camera Lens Replacement, Rear Camera Lens: passo 1, immagine 1 di 1
    • Start by placing your phone screen down on a clean, well-lit surface.
    • Wear safety glasses/goggles to protect your eyes from glass shards. This is very important.
  2. Huawei P20 Pro Rear Camera Lens Replacement: passo 2, immagine 1 di 2 Huawei P20 Pro Rear Camera Lens Replacement: passo 2, immagine 2 di 2
    • Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal.
    • A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
  3. Huawei P20 Pro Rear Camera Lens Replacement: passo 3, immagine 1 di 1
    • Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • If not available, place double-sided adhesive strips in the gaps between the cameras.
    • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
  4. Huawei P20 Pro Rear Camera Lens Replacement: passo 4, immagine 1 di 1
    • All done! You can take pictures again like you were able to do before.
Conclusione
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
Altre 17 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
cPix
Membro da: 06/14/16
3.971 Reputazione
8 Guide realizzate
2 Commenti
Tuto très bien expliquer je vais pouvoir maintenant reprendre de belles photos grâce à vous. Merci
Ace Ace - Replica
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
256 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 140
Tutti i Tempi: 57,963
