Introduzione
In this guide we show you how to remove and replace a worn out or defective battery in your Huawei P10 Plus smartphone.
If your new part does not come with adhesive, you will also need to purchase replacement adhesive.
Cosa ti serve
Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
Remove the 13 Phillips #00 screws.
Remove the metal shield which holds down the display flex connector.
There is a stretch-release adhesive tab between the battery and the motherboard, use tweezers to pull them from the gap before you begin pulling.
Peel out the adhesive strip by steadily pulling at the tab in a flat angle.
Follow the heating instructions and place an iOpener over the battery to soften the remaining adhesive strip.
The daughterboard interconnect cable runs beneath the right side of the battery, as shown in red. Avoid prying in this area.
Insert a spudger beneath the top left corner of the battery and carefully pry it out. You can also use an old gift card or credit card.
If you can lever the battery to the right and remove it, do so, otherwise cut the remaining adhesive on the left side. Then repeat the procedure on the right side of the battery, avoiding the cable area.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Altre 15 persone hanno completato questa guida.
4 Commenti
good guide, took me a hour
the pull tab got torn when i tried pulling it so i had to get the battery out in the old fashion way praying it wont explode
edit: i had 14 screws not 15
Guida fatta bene Ok mi è venuta comodissima e o risolto sostituendo batteria ,vetro e carcassa in 30 min circa . Grazie
Vielen Dank für diese super Anleitung, hat alles prima geklappt. Einzig der Accu wollte nicht so leicht rausgehen.
