Salta al contenuto principale
Huawei P10 Lite Back cover Replacement
Cosa ti serve
  1. Huawei P10 Lite Back cover Replacement, Back cover: passo 1, immagine 1 di 3 Huawei P10 Lite Back cover Replacement, Back cover: passo 1, immagine 2 di 3 Huawei P10 Lite Back cover Replacement, Back cover: passo 1, immagine 3 di 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Back cover Replacement: passo 2, immagine 1 di 3 Huawei P10 Lite Back cover Replacement: passo 2, immagine 2 di 3 Huawei P10 Lite Back cover Replacement: passo 2, immagine 3 di 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Back cover Replacement: passo 3, immagine 1 di 2 Huawei P10 Lite Back cover Replacement: passo 3, immagine 2 di 2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Back cover Replacement: passo 4, immagine 1 di 2 Huawei P10 Lite Back cover Replacement: passo 4, immagine 2 di 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
Conclusione
Altre 15 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
6 Commenti
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Replica
You need to warm the adhesive so it can be loose
Adwell Cellular -
What adhesive should I use? Thank you!
Calin GV - Replica
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Replica
Can you send me please back cover.
I'm from Nepal .
Md Usman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 108
Tutti i Tempi: 38,447
