Salta al contenuto principale
Huawei P10 Headphone Jack Replacement
Cosa ti serve
  1. Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, immagine 1 di 3 Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, immagine 2 di 3 Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, immagine 3 di 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Headphone Jack Replacement: passo 2, immagine 1 di 3 Huawei P10 Headphone Jack Replacement: passo 2, immagine 2 di 3 Huawei P10 Headphone Jack Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Headphone Jack Replacement: passo 3, immagine 1 di 2 Huawei P10 Headphone Jack Replacement: passo 3, immagine 2 di 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, immagine 1 di 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, immagine 2 di 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Headphone Jack Replacement, Headphone Jack: passo 5, immagine 1 di 2 Huawei P10 Headphone Jack Replacement, Headphone Jack: passo 5, immagine 2 di 2
    • Remove the three Phillips #00 screws.
  6. Huawei P10 Headphone Jack Replacement: passo 6, immagine 1 di 2 Huawei P10 Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
Conclusione
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Altre 2 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
123 Membri
25.671 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 86
Tutti i Tempi: 3,310
