Salta al contenuto principale
Introduzione
Use this guide to replace the headphone jack in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. Getting the prying tool in  will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Remove the Phillips #00 screw. Use tweezers to remove the metal plate. Use a spudger to disconnect the battery flex cable.
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Remove the three Phillips #00 screws. Use tweezers to remove the metal plate.
    • Remove the three Phillips #00 screws.
  6. Use the flat end of a spudger to disconnect the headphone jack. Remove the headphone jack.
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
Conclusione
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Altre 2 persone hanno completato questa guida.
Dominik Schnabelrauch
Membro da: 23/11/2016
102.708 Reputazione
413 Guide realizzate
iFixit Membro di iFixit
Community
140 Membri
15.635 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,439
