Salta al contenuto principale
Huawei P10 Back Cover Replacement
Cosa ti serve
  1. Huawei P10 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Huawei P10 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Huawei P10 Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Back Cover Replacement: passo 2, immagine 1 di 3 Huawei P10 Back Cover Replacement: passo 2, immagine 2 di 3 Huawei P10 Back Cover Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Back Cover Replacement: passo 3, immagine 1 di 2 Huawei P10 Back Cover Replacement: passo 3, immagine 2 di 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
Conclusione
Altre 6 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 52
Tutti i Tempi: 7,788
