Salta al contenuto principale
Huawei MediaPad S7-301u Battery Replacement
Cosa ti serve
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, immagine 1 di 3 Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, immagine 2 di 3 Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: passo 2, immagine 1 di 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: passo 3, immagine 1 di 3 Huawei MediaPad S7-301u Battery Replacement: passo 3, immagine 2 di 3 Huawei MediaPad S7-301u Battery Replacement: passo 3, immagine 3 di 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: passo 4, immagine 1 di 3 Huawei MediaPad S7-301u Battery Replacement: passo 4, immagine 2 di 3 Huawei MediaPad S7-301u Battery Replacement: passo 4, immagine 3 di 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Miguel Lugo
Membro da: 09/26/17
598 Reputazione
3 Guide realizzate
USF Tampa, Team S11-G5, Passmore Fall 2017 Membro di USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Membri
8 Guide realizzate
Un commento
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 7,015
