Salta al contenuto principale
Huawei Mate 8 Loudspeaker Replacement
Cosa ti serve
  1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: passo 1, immagine 1 di 2 Huawei Mate 8 Loudspeaker Replacement, Back Cover: passo 1, immagine 2 di 2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Loudspeaker Replacement: passo 2, immagine 1 di 1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Loudspeaker Replacement: passo 3, immagine 1 di 2 Huawei Mate 8 Loudspeaker Replacement: passo 3, immagine 2 di 2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Loudspeaker Replacement: passo 4, immagine 1 di 3 Huawei Mate 8 Loudspeaker Replacement: passo 4, immagine 2 di 3 Huawei Mate 8 Loudspeaker Replacement: passo 4, immagine 3 di 3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: passo 5, immagine 1 di 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: passo 5, immagine 2 di 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: passo 5, immagine 3 di 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Loudspeaker Replacement: passo 6, immagine 1 di 3 Huawei Mate 8 Loudspeaker Replacement: passo 6, immagine 2 di 3 Huawei Mate 8 Loudspeaker Replacement: passo 6, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Loudspeaker Replacement: passo 7, immagine 1 di 1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Loudspeaker Replacement: passo 8, immagine 1 di 2 Huawei Mate 8 Loudspeaker Replacement: passo 8, immagine 2 di 2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Loudspeaker Replacement: passo 9, immagine 1 di 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Loudspeaker Replacement, Charging Board: passo 10, immagine 1 di 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: passo 10, immagine 2 di 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: passo 10, immagine 3 di 3
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  11. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: passo 11, immagine 1 di 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: passo 11, immagine 2 di 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: passo 11, immagine 3 di 3
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
Conclusione
Altre 4 persone hanno completato questa guida.
Theo Mat
Membro da: 11/12/17
12.790 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,016
