Salta al contenuto principale
Huawei Mate 10 Pro Daughterboard Replacement
Cosa ti serve
  1. Huawei Mate 10 Pro Daughterboard Replacement, SIM Card Tray: passo 1, immagine 1 di 2 Huawei Mate 10 Pro Daughterboard Replacement, SIM Card Tray: passo 1, immagine 2 di 2
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Daughterboard Replacement, Back Cover: passo 2, immagine 1 di 1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Daughterboard Replacement: passo 3, immagine 1 di 3 Huawei Mate 10 Pro Daughterboard Replacement: passo 3, immagine 2 di 3 Huawei Mate 10 Pro Daughterboard Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Daughterboard Replacement: passo 4, immagine 1 di 2 Huawei Mate 10 Pro Daughterboard Replacement: passo 4, immagine 2 di 2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Daughterboard Replacement: passo 5, immagine 1 di 2 Huawei Mate 10 Pro Daughterboard Replacement: passo 5, immagine 2 di 2
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  6. Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: passo 6, immagine 1 di 3 Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: passo 6, immagine 2 di 3 Huawei Mate 10 Pro Daughterboard Replacement, Daughterboard: passo 6, immagine 3 di 3
    • Unscrew the back cover from the base, then remove black cover.
    • Screws can be placed on a magnetic board to reduce chance of being lost.
  7. Huawei Mate 10 Pro Daughterboard Replacement: passo 7, immagine 1 di 1
    • Unhook black strip over battery at both ends and remove.
  8. Huawei Mate 10 Pro Daughterboard Replacement: passo 8, immagine 1 di 3 Huawei Mate 10 Pro Daughterboard Replacement: passo 8, immagine 2 di 3 Huawei Mate 10 Pro Daughterboard Replacement: passo 8, immagine 3 di 3
    • Pop out daughterboard and disconnect black and white wires.
Conclusione
IUPUI, Team 3-5, Harley Spring 2022 Membro di IUPUI, Team 3-5, Harley Spring 2022
IUPUI-HARLEY-S22S3G5
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 72
Tutti i Tempi: 950
