Salta al contenuto principale
Huawei Mate 10 Pro Back Cover Replacement
Cosa ti serve
  1. Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: passo 1, immagine 1 di 2 Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: passo 1, immagine 2 di 2
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  2. Huawei Mate 10 Pro Back Cover Replacement, Back Cover: passo 2, immagine 1 di 1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Huawei Mate 10 Pro Back Cover Replacement: passo 3, immagine 1 di 3 Huawei Mate 10 Pro Back Cover Replacement: passo 3, immagine 2 di 3 Huawei Mate 10 Pro Back Cover Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
    Chiedi a FixBot
    Aggiungi Commento
  4. Huawei Mate 10 Pro Back Cover Replacement: passo 4, immagine 1 di 2 Huawei Mate 10 Pro Back Cover Replacement: passo 4, immagine 2 di 2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
    Chiedi a FixBot
    Aggiungi Commento
  5. Huawei Mate 10 Pro Back Cover Replacement: passo 5, immagine 1 di 2 Huawei Mate 10 Pro Back Cover Replacement: passo 5, immagine 2 di 2
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 14 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
122 Membri
25.930 guide realizzate
3Commenti sulla guida
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Luis Liberato - Rispondi Condividi
Thanks for good work you do
amoudi Guide - Rispondi Condividi
Thanks for the job
When reassembling the phone what kind of adhesive can I use ?
email me at : aptel.one@proton.me
Thanks for your reply
Jds75 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 22
Ultimi 30 giorni: 81
Tutti i Tempi: 18,222
