Introduzione
This will enable the user to correct any problems with the mini-usb port if it has malfunctioned.
Cosa ti serve
Place the tablet on a flat clear surface to keep the screen safe.
Slide the larger portion of the back cover off the tablet.
This will reveal the battery.
Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Heat the solder to the mini-USB port.
Remove the melted solder using a solder sucker or desoldering braid.
Replace the old mini-USB port with a new one by attaching it using a new solder.
Let cool, then replace logic board in tablet.
