Salta al contenuto principale
Huawei Honor 8 Screen Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Huawei Honor 8 Screen Replacement, Remove the back casing: passo 1, immagine 1 di 3 Huawei Honor 8 Screen Replacement, Remove the back casing: passo 1, immagine 2 di 3 Huawei Honor 8 Screen Replacement, Remove the back casing: passo 1, immagine 3 di 3
    • Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun.
    • Attention: The sides have to be hot, not scalding.
    • Insert the iSesamo delicatley between the two sides (see photo)
    • Once the iSesamo is inserted, slide it along the sides to remove the adhesive.
    • ATTENTION: DO NOT SLIDE THE ISESEMO ALONG THE PART MARKED IN GREEN.
  2. Huawei Honor 8 Screen Replacement, Disconnect the rear window: passo 2, immagine 1 di 2 Huawei Honor 8 Screen Replacement, Disconnect the rear window: passo 2, immagine 2 di 2
    • Remove the screw on the metal plate which protects the fingerprint sensor cable
    • Remove the the fingerprint censor cable using a plastic spudger.
  3. Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: passo 3, immagine 1 di 3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: passo 3, immagine 2 di 3 Huawei Honor 8 Screen Replacement, Remove the protection from the motherboard: passo 3, immagine 3 di 3
    • Remove the 16 screws with a Phillips screwdriver.
    • Using the iSesamo, remove the protection from the motherboard
  4. Huawei Honor 8 Screen Replacement, Take off the battery: passo 4, immagine 1 di 3 Huawei Honor 8 Screen Replacement, Take off the battery: passo 4, immagine 2 di 3 Huawei Honor 8 Screen Replacement, Take off the battery: passo 4, immagine 3 di 3
    • Remove the 2 tabs marked in red.
    • Gently remove the battery with a playing card or bank card.
  5. Huawei Honor 8 Screen Replacement, Prepare to take off the screen: passo 5, immagine 1 di 2 Huawei Honor 8 Screen Replacement, Prepare to take off the screen: passo 5, immagine 2 di 2
    • Peel off the connector on the screen.
    • Heat the contours of the screen as shown in Step 1.
  6. Huawei Honor 8 Screen Replacement, Take off the screen: passo 6, immagine 1 di 2 Huawei Honor 8 Screen Replacement, Take off the screen: passo 6, immagine 2 di 2
    • insert the iSesamo between the screen and the chassis
    • Be sure to pass the iSesamo under the white plate of the screen (see photo)
    • Go around the phone.
    • Note that the operation can be more complicated depending on the level of the screen.
  7. Huawei Honor 8 Screen Replacement, Clean the frame: passo 7, immagine 1 di 2 Huawei Honor 8 Screen Replacement, Clean the frame: passo 7, immagine 2 di 2
    • Carefully remove the pieces of glass and the adhesive on the frame
    • Glue the screen on the frame by passing the sheet through the hole provided for this purpose
Conclusione
To reassemble your device, follow the instructions in reverse order :)
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Nihoul Victor
Membro da: 04/23/17
261 Reputazione
1 Guida realizzata
4 Commenti
Est-ce que quelqu'un a essayer ? a combien estimez vous la réparation: ecran + accessoires ? Car le lien ne fonctionne pas. En tout cas tuto très bien réalisé ;)
fabien6-8ol - Replica
Moi forcement ...
Chez moi le lien fonctionne, la pièce est à 55,99€, tu peux demander des accessoires gratuit
Nihoul Victor - Replica
Sinon merci ;)
Bonjour
Merci pour ce tuto. J'aurais juste une question.
Comment recollé la vitre arrière après la réparation ?
J'ai déjà eu le cas sur un smartphone Sony et je n'ai pas réussi à correctement recollé la face arrière.
Merci a bientôt
Comoretto Quentin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,231
