Introduzione
Use this guide to remove and replace a broken or defective rear camera in the Huawei Honor 8.
You’ll need replacement adhesive to reattach components when reassembling the device.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Remove these Phillips #00 screws securing the midframe bezel:
Eight screws with 3.5 mm length
Eight screws with 2.9 mm length
Some screws might be covered with a tamper proof sticker.
Use a spudger to pry up and disconnect the rear camera flex cable from its motherboard socket.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
