Salta al contenuto principale
Huawei Honor 8 LCD Display Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Huawei Honor 8 LCD Display Replacement, Rear Glass & Frame: passo 1, immagine 1 di 1
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device.
  2. Huawei Honor 8 LCD Display Replacement: passo 2, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 2, immagine 2 di 2
    • Be careful not to tear the orange ribbon wire when removing the back panel.
    • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
    • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
    • Additional plastic opening tools can be used to help separate the back panel from the phone body.
    • Gently lift the back panel off once all the adhesive has been removed.
  3. Huawei Honor 8 LCD Display Replacement: passo 3, immagine 1 di 3 Huawei Honor 8 LCD Display Replacement: passo 3, immagine 2 di 3 Huawei Honor 8 LCD Display Replacement: passo 3, immagine 3 di 3
    • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
    • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
    • Gently pry off the orange ribbon wire on the back panel.
  4. Huawei Honor 8 LCD Display Replacement: passo 4, immagine 1 di 1
    • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
    • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
    • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
    • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
    • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
    • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
  5. Huawei Honor 8 LCD Display Replacement: passo 5, immagine 1 di 3 Huawei Honor 8 LCD Display Replacement: passo 5, immagine 2 di 3 Huawei Honor 8 LCD Display Replacement: passo 5, immagine 3 di 3
    • Slowly slide the plastic opening tool around the perimeter of the inner lining.
    • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
    • Gently pull the inner lining up to remove it from the phone body.
  6. Huawei Honor 8 LCD Display Replacement, Motherboard: passo 6, immagine 1 di 3 Huawei Honor 8 LCD Display Replacement, Motherboard: passo 6, immagine 2 di 3 Huawei Honor 8 LCD Display Replacement, Motherboard: passo 6, immagine 3 di 3
    • Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
    • Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
    • Gently pull out the Sim Card tray and set it aside.
  7. Huawei Honor 8 LCD Display Replacement: passo 7, immagine 1 di 1
    • In the following steps you will disconnect the five connectors circled in red holding the motherboard in place.
  8. Huawei Honor 8 LCD Display Replacement: passo 8, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 8, immagine 2 di 2
    • Gently pull the small ribbon connection between the battery and motherboard upward to disconnect it.
    • Use a spudger to help pry off the connection if necessary.
  9. Huawei Honor 8 LCD Display Replacement: passo 9, immagine 1 di 1
    • Use a spudger to gently pry off the small antenna cable on the right side of the motherboard.
  10. Huawei Honor 8 LCD Display Replacement: passo 10, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 10, immagine 2 di 2
    • Using a spudger, gently pry up the small connection that holds the motherboard in place.
  11. Huawei Honor 8 LCD Display Replacement: passo 11, immagine 1 di 1
    • Using a spudger, gently pry up the connector near the left edge of the motherboard.
  12. Huawei Honor 8 LCD Display Replacement: passo 12, immagine 1 di 1
    • Use a spudger to gently pry off the small connection on the far left edge of the motherboard.
  13. Huawei Honor 8 LCD Display Replacement: passo 13, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 13, immagine 2 di 2
    • Use a spudger to pry up a corner of the motherboard.
    • Lift the motherboard to remove it from the body of the phone.
  14. Huawei Honor 8 LCD Display Replacement, Battery: passo 14, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement, Battery: passo 14, immagine 2 di 2
    • Using a spudger, pry off the small connection between the speaker and phone body located near the bottom of the device circled in red.
    • Gently pry up a corner of the speaker using a spudger.
    • Lift the speaker up and out of the phone body.
  15. Huawei Honor 8 LCD Display Replacement: passo 15, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 15, immagine 2 di 2
    • Avoid using a heat gun for this step as overheating the battery can cause permanent damage.
    • You may use an iOpener on the front side of the phone to safely heat and loosen the adhesive under the battery.
    • Insert the plastic spudger into the gap between the frame and the battery.
    • Move the spudger around the outside edge of the battery to remove the adhesive.
    • Do not bend or puncture the battery. There is a lot of adhesive holding the battery in place, moving the spudger may require some effort. Use the plastic opening tools to help pry each side open.
  16. Huawei Honor 8 LCD Display Replacement: passo 16, immagine 1 di 3 Huawei Honor 8 LCD Display Replacement: passo 16, immagine 2 di 3 Huawei Honor 8 LCD Display Replacement: passo 16, immagine 3 di 3
    • Once all the adhesive has been removed from the battery, use the spudger and plastic opening tools to gently pry the battery away from the frame.
  17. Huawei Honor 8 LCD Display Replacement, LCD Display: passo 17, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement, LCD Display: passo 17, immagine 2 di 2
    • Gently pull the ribbon cable that connects the LCD screen away from the phone body.
  18. Huawei Honor 8 LCD Display Replacement: passo 18, immagine 1 di 1
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the LCD Display too early can result in cracking the glass.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the LCD Display to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device. You may also use an iOpener to apply heat evenly along the perimeter of the screen.
  19. Huawei Honor 8 LCD Display Replacement: passo 19, immagine 1 di 2 Huawei Honor 8 LCD Display Replacement: passo 19, immagine 2 di 2
    • Using a plastic opening tool, gently pry up a corner of the LCD Display.
    • Slowly slide the plastic opening tool around the outside of the LCD Display to break through the adhesive.
    • Once all the adhesive has been removed, gently lift the LCD Display off.
Conclusione
Altre 9 persone hanno completato questa guida.
Jaret Wedow
Membro da: 09/25/17
1.800 Reputazione
4 Guide realizzate
Cal Poly, Team S18-G2, Forte Fall 2017 Membro di Cal Poly, Team S18-G2, Forte Fall 2017
CPSU-FORTE-F17S18G2
4 Membri
24 Guide realizzate
5Commenti sulla guida
When removing the LCD I wrongly thought the line on the metal frame was where I should pry and damaged it. You should include a closeup in the guide to show the two and let people know which one to start sticking stuff into. It required a lot of force to get the screen off, the metal frame actually bent outwards from the pressure..
Andreas Østhus Saltveit - Replica
When opening the back cover, make sure not to pry the glass itself off, there’s a really thin piece of plastic (?) behind it. I almost destroyed the cover because of it.
robonxt - Replica
When removing the antenna, don’t force, try removing the antenna by the cable. I broke the connector because it was hard, I somehow managed to repair it (by solder) but DON’T DO THAT the connector is 1mm long, it’s nearly impossible to repair
Gabmiral - Replica
I have just finished replacing the battery and the screen one this smartphone and it took me forever !!! Unfortunately I forgot to put back the metal tab that holds the screen and fingerprint cable and I am wondering if that is going to be an issue for me in the future as I really don’t want to open the device again !!!
Adel Hachmi - Replica
I accidentaly broke the charging cable under the battery while trying to remove the damm thing. The replacment cable is a bit longer. For me the metal tabs are necessary to hold the connectors in place. I supposse in your case everything should be fine.
Jonas Linter -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,729
