Salta al contenuto principale
Huawei Honor 6x Front Camera Replacement
Cosa ti serve
  1. Huawei Honor 6x Front Camera  Replacement, SIM Card: passo 1, immagine 1 di 1
    • Turn off the device.
  2. Huawei Honor 6x Front Camera  Replacement: passo 2, immagine 1 di 2 Huawei Honor 6x Front Camera  Replacement: passo 2, immagine 2 di 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Front Camera  Replacement: passo 3, immagine 1 di 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Front Camera  Replacement: passo 4, immagine 1 di 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Front Camera  Replacement, Back Cover: passo 5, immagine 1 di 2 Huawei Honor 6x Front Camera  Replacement, Back Cover: passo 5, immagine 2 di 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Front Camera  Replacement: passo 6, immagine 1 di 3 Huawei Honor 6x Front Camera  Replacement: passo 6, immagine 2 di 3 Huawei Honor 6x Front Camera  Replacement: passo 6, immagine 3 di 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Front Camera  Replacement: passo 7, immagine 1 di 2 Huawei Honor 6x Front Camera  Replacement: passo 7, immagine 2 di 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Front Camera  Replacement: passo 8, immagine 1 di 3 Huawei Honor 6x Front Camera  Replacement: passo 8, immagine 2 di 3 Huawei Honor 6x Front Camera  Replacement: passo 8, immagine 3 di 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Front Camera  Replacement: passo 9, immagine 1 di 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Front Camera  Replacement, Front Camera: passo 10, immagine 1 di 3 Huawei Honor 6x Front Camera  Replacement, Front Camera: passo 10, immagine 2 di 3 Huawei Honor 6x Front Camera  Replacement, Front Camera: passo 10, immagine 3 di 3
    • Pry the seven connectors off using a spudger or your finger.
  11. Huawei Honor 6x Front Camera  Replacement: passo 11, immagine 1 di 3 Huawei Honor 6x Front Camera  Replacement: passo 11, immagine 2 di 3 Huawei Honor 6x Front Camera  Replacement: passo 11, immagine 3 di 3
    • Remove the four 2 mm Phillips #00 screws.
  12. Huawei Honor 6x Front Camera  Replacement: passo 12, immagine 1 di 2 Huawei Honor 6x Front Camera  Replacement: passo 12, immagine 2 di 2
    • Lift the motherboard off of the phone using a spudger or two fingers.
    • The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
  13. Huawei Honor 6x Front Camera  Replacement: passo 13, immagine 1 di 2 Huawei Honor 6x Front Camera  Replacement: passo 13, immagine 2 di 2
    • Remove the cable connecting the camera from the motherboard using a spudger or your finger.
  14. Huawei Honor 6x Front Camera  Replacement: passo 14, immagine 1 di 3 Huawei Honor 6x Front Camera  Replacement: passo 14, immagine 2 di 3 Huawei Honor 6x Front Camera  Replacement: passo 14, immagine 3 di 3
    • Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
    • This is best done from the back side of the motherboard and pushing where the cable meets the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Tessa Kemper
Membro da: 10/08/18
591 Reputazione
3 Guide realizzate
Cal Poly, Team S13-G5, White Fall 2018 Membro di Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,010
