Salta al contenuto principale
Huawei Honor 20 lite battery Replacement
Cosa ti serve
  1. Huawei Honor 20 lite battery Replacement, heating back cover: passo 1, immagine 1 di 1
    • Place phone on a heating bed.
    • I set it to 80 degrees celcius and left it on there for 5 minutes.
  2. Huawei Honor 20 lite battery Replacement, removing the back cover: passo 2, immagine 1 di 1
    • once the glue is softened, use the plastic pick tool to loosen one edge.
    • leave a pick under one side to stop that side from re-sticking as you move onto the next edge.
  3. Huawei Honor 20 lite battery Replacement, undoing the screws: passo 3, immagine 1 di 2 Huawei Honor 20 lite battery Replacement, undoing the screws: passo 3, immagine 2 di 2
    • place the back cover side by side with the rest of he phone. being careful a the fingerprint scanner cable is on the back of the phone
    • take out all the screws in the bottom part of the phone and gently lift off, away from the phone.
    • unclip the ribbon cable.
  4. Huawei Honor 20 lite battery Replacement, top screws: passo 4, immagine 1 di 1
    • next repeat the same process along the top part. (be careful with the cameras, the cover should just unclip without much effort.)
    • be careful of the 2 screws circled. these need to come out as well.
  5. Huawei Honor 20 lite battery Replacement, pulling battery tabs: passo 5, immagine 1 di 2 Huawei Honor 20 lite battery Replacement, pulling battery tabs: passo 5, immagine 2 di 2
    • gently pry the battery terminal away from the board
    • next pull tab 1 and 2 individually.
  6. Huawei Honor 20 lite battery Replacement, battery removal: passo 6, immagine 1 di 1
    • when you pull tab 3, the battery should hinge away from you and then pull towards you .
    • insert a new battery and repeat the steps backwards.
Conclusione
chris dodds
Membro da: 11/15/20
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 62
Tutti i Tempi: 886
