Salta al contenuto principale
Huawei Ascend W1 Battery Replacement
  1. Huawei Ascend W1 Battery Replacement, The phone's orientation.: passo 1, immagine 1 di 1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Battery Replacement, Removing the back cover.: passo 2, immagine 1 di 1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Battery Replacement: passo 3, immagine 1 di 1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Battery Replacement, Removing the battery.: passo 4, immagine 1 di 3 Huawei Ascend W1 Battery Replacement, Removing the battery.: passo 4, immagine 2 di 3 Huawei Ascend W1 Battery Replacement, Removing the battery.: passo 4, immagine 3 di 3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
Conclusione
Altre 2 persone hanno completato questa guida.
Jaie Hillery
Membro da: 10/07/14
1.718 Reputazione
10 Guide realizzate
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro di USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,150
