Salta al contenuto principale
Introduzione
Follow this guide to replace the back panel on your Huawei Ascend P6-U06.
  1. Firmly push down on the black plastic covering at the bottom of the phone, and pull down. You may need a sharp thin object to get underneath the plastic.
    • Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
    • You may need a sharp thin object to get underneath the plastic.
  2. Rotate the phone 180 degrees so that the bottom of the phone is now facing up. Firmly push up on the back panel with your thumbs.
    • Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
    • Firmly push up on the back panel with your thumbs.
    • Lift up the back panel from the top right corner and gently pull it away from the phone.
Conclusione
Altre 13 persone hanno completato questa guida.
Alison Jones
Membro da: 14/10/2014
391 Reputazione
1 Guida realizzata
Cal Poly, Team 4-44, Amido Fall 2014 Membro di Cal Poly, Team 4-44, Amido Fall 2014
CPSU-AMIDO-F14S4G44
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 4,971
