Salta al contenuto principale
Hp Pavilion dv6-2155dx Optical Drive Replacement
Cosa ti serve
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: passo 1, immagine 1 di 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: passo 1, immagine 2 di 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 2, immagine 1 di 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 3, immagine 1 di 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 3, immagine 2 di 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 4, immagine 1 di 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: passo 4, immagine 2 di 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Conclusione
Altre 2 persone hanno completato questa guida.
Joseph Sanda
Membro da: 03/10/16
522 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 767
