Salta al contenuto principale
Hp 15-f305dx Wi-Fi Card Replacement
Cosa ti serve
  1. Hp 15-f305dx Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Wi-Fi Card Replacement: passo 3, immagine 1 di 3 Hp 15-f305dx Wi-Fi Card Replacement: passo 3, immagine 2 di 3 Hp 15-f305dx Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Hp 15-f305dx Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Wi-Fi Card Replacement, Wi-Fi Card: passo 5, immagine 1 di 1
    • Unscrew two 5mm Phillips #00 screws on the back service cover.
  6. Hp 15-f305dx Wi-Fi Card Replacement: passo 6, immagine 1 di 2 Hp 15-f305dx Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Remove the service panel.
  7. Hp 15-f305dx Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Remove a single 5 mm Phillips #00 screw holding the Wi-Fi card in place.
  8. Hp 15-f305dx Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Remove the black and white cable connections by prying the connections up with a spudger.
    • They should "pop" off of the card.
  9. Hp 15-f305dx Wi-Fi Card Replacement: passo 9, immagine 1 di 1
    • Using your fingers, gently remove the Wi-Fi card from the laptop by sliding it outward from its port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 569
