Parti
Nessuna parte richiesta.
  1. Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Turn the computer upside down on a flat surface.
    • Turn the computer upside down on a flat surface.
  3. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery. Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Lift the battery from the middle and then pivot it outward to remove it from the comp. Lift the battery from the middle and then pivot it outward to remove it from the comp.
    • Lift the battery from the middle and then pivot it outward to remove it from the comp.
  6. Remove the bezel by prying it away from the screen using the spudger. Remove the bezel by prying it away from the screen using the spudger.
    • Remove the bezel by prying it away from the screen using the spudger.
  7. Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
    • Remove the four 3mm PH1 Phillips head screws in each corner of the screen and do not care about outer screws.
  8. Remove the screen and place the screen very softly on the keyboard.
    • Remove the screen and place the screen very softly on the keyboard.
  9. Remove the sticker gently and disconnect the metal blade. Remove the sticker gently and disconnect the metal blade.
    • Remove the sticker gently and disconnect the metal blade.
Conclusione
Brandon
Membro da: 23/03/2018
613 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 127
