Salta al contenuto principale
How to wind back the EPB, electronic parking brake, to change rear brake pads
Cosa ti serve
Panoramica video
    • Insert wisdom here.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Just follow the video for how to change the rear pads on cars fitted with EPB. This is on a Discovery Sport but applies to others.
Altre 2 persone hanno completato questa guida.
jon
Membro da: 05/15/16
3.384 Reputazione
22 guide realizzate
4Commenti sulla guida
Excellent tutorial, clear and easy to follow, perfect if you are a novice, looking for the same for the front pads now.
alanmac28@tiscali.co.uk - Rispondi Condividi
The front pads should be a lot easier because there’s no awkward handbrake to deal with just push back the caliper pistons with a long screwdriver pushing it evenly both sides.
jon - Rispondi Condividi
You can also rewind them using a 12v source rather than taking the cover off (I was worried on my scenic that it might leak if I broke the seal). The cars know when to stop winding as they sence the current increase when the motor jams. We humans can just use our ears. As long as you take the wire off the battery the very second the motor stops you’ll be fine.
Here is me doing mine this weekend.
https://youtu.be/kGn7tEjr600
James Taylor - Rispondi Condividi
Discover 150cc bike shocker problem how to repair
Md Shahid - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 28
Ultimi 30 giorni: 113
Tutti i Tempi: 42,983
