Salta al contenuto principale
Introduzione
If your mac is having trouble recognizing a replacement battery or other components, you may need to repair your main disk permissions. Follow this guide as a first step in troubleshooting.
  1. You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities Or you can take the shortcut and use Spotlight!
    • You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
    • Or you can take the shortcut and use Spotlight!
    1.21 gigawatts! 1.21 gigawatts. Great Scott!
    Doc Brown - Replica
  2. Once opened, you should be presented with a window that looks like this. You will want to select the name of your Mac OS X Startup disk in the left column.
    • Once opened, you should be presented with a window that looks like this.
    • You will want to select the name of your Mac OS X Startup disk in the left column.
    • After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
    • The First Aid heading is what you will want to be under.
    • Click on the Verify Disk Permissions, starting the process.
  3. This usually will take anywhere from 3 minutes to 15 minutes.  The best thing to do is to wait. As time progresses, you will see information pop up in the window highlighted.
    • This usually will take anywhere from 3 minutes to 15 minutes. The best thing to do is to wait.
    • As time progresses, you will see information pop up in the window highlighted.
    • This is good, it means that it is seeing the problems that may be keeping your computer from running well.
  4. After verifying the disk permissions, go ahead and select repair disk permissions to start that process. During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
    • After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
    • During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
    What do you for if not sll the permissions are fixed,?
    thomas buckley - Replica
    What do you do for a few minutes if there is no cat to pet?
    Cooper - Replica
    Twiddle your thumbs maybe? That seems like a good idea.
    Mike -
    You should definitely get a cat! :) -suzanne
    Suzanne Bell -
    Mike - Replica
    Looks like as of Catalina at least these instructions are a little outdated as the Disk Utility UI has changed such that several referenced buttons don’t really exist. Should probably update for both Catalina and Big Sur, which I’m guessing is even more different. Thanks!
    Kevin Pettitt - Replica
Conclusione
Congrats! You successfully repaired your disk permissions!
Altre 51 persone hanno completato questa guida.
Mike
Membro da: 01/11/2010
13.766 Reputazione
3 Guide realizzate
verify disk does not come up after I enter fix and the procedure stops, I am running high sierra 10.13.6, Help please
gene kaz - Replica
Did anyone help you? I'm running through the same issues?
Marco Saavedra -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 70
Tutti i Tempi: 10,840
