Introduzione
This guide will help walk you though the unclogging of the Keurig Mini's water drain. You will need a #1 Philips screw driver to get inside of the device.
Cosa ti serve
Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
Open the top lid of the Keurig.
Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails. The arms are identical for both sides so once one side is free repeat the process for the second side.
Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
Lift up the top arm assembly to get it out of the way. Once it is out of the way, clear out any obstructions in the drain.
Use your finger or a slender object to clean the drain. Avoid pushing material further down the drain as that may cause obstructions deeper in the system.
Altre 13 persone hanno completato questa guida.
10 Commenti
This helped a lot. I used a large syringe. We used to raise birds & had a variety of sizes. Put the syringe on the tube & pulled several times.Seemed to free any clog at the very bottom. Put back together & it's working now.but I notice sprinkles of water as is heats up now. Just need to figure what could be causing this.
So my keurig was not clogged. BUT. After taking it apart and putting it back together, it works now! #sweetcaffeinatedvictory
This was very helpful. My Keurig is working again. Thanks.
