Introduzione
This guide shows how to tighten the main wheels on the wheelchair.
Strumenti
Parti
Nessuna parte richiesta.
Inspect chair to see which wheel is loose.
  • Inspect chair to see which wheel is loose.
  • Tighten the outer bolt with a 19 mm socket wrench.
  • Tighten the nut on the inside with a 19 mm wrench.
Aggiungi Commento
Conclusione
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Kali Slaughter
Membro da: 19/04/2013
207 Reputazione
5 Guide realizzate
Cal Poly, Team 14-8, Maness Spring 2013 Membro di Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 801
