Introduzione
It's easy to test an infrared (IR) remote control using a mobile phone's camera (most phone cameras are sensitive to IR). This helps when debugging a gadget problem.
Cosa ti serve
Place the remote control facing the camera lens Turn the camera on, and check that you can see the remote control's front face.
Press buttons on the remote control.
If you can see a light in the camera screen then the remote is functioning!
Note: this doesn't test that the data sent by the remote is correct.
3Commenti sulla guida
What might be the problem if it is always blinking, but it stops when I press any of the buttons?
Coby TV-DVD 1350 remote that was bought second hand, if that helps.
Faulty electronics or push-button switches. You could try squirting in some contact cleaner
