Salta al contenuto principale
How to strip Cat.7 S/FTP PiMF Ethernet Cable
Cosa ti serve
  1. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: passo 1, immagine 1 di 2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: passo 1, immagine 2 di 2
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: passo 2, immagine 1 di 2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: passo 2, immagine 2 di 2
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: passo 3, immagine 1 di 3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: passo 3, immagine 2 di 3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: passo 3, immagine 3 di 3
    • Pull back the grounding mesh and twist it around the first cm of still insulated cable.
    • You can leave the excess, but if you want to cut it, make sure to leave at least about 1cm.
  4. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Spread the twisted pairs: passo 4, immagine 1 di 1
    • Spread out the twisted pairs to make them easier to work with.
  5. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: passo 5, immagine 1 di 2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flush Cutter
    $29.99
    • Unwrap the shielding a bit and nick it at the base with some electronics side cutters.
    • If you will wire this cable in a terminal block instead of a Keystone or crimping on a connector, you should just remove the minimum amount of shielding needed to properly punch down the connection.
    • Make sure to not damage the delicate insulation of the individual wires.
    • Rip off the shielding.
    • Repeat for all four twisted pairs.
  6. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): passo 6, immagine 1 di 3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): passo 6, immagine 2 di 3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): passo 6, immagine 3 di 3
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.3 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
Conclusione
Good luck on your next project!
Altre 2 persone hanno completato questa guida.
Sebastian
Membro da: 08/19/18
31.160 Reputazione
71 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 95
Tutti i Tempi: 2,726
