Introduzione
This guide will show you how to repair your 1984-1989 Toyota 4Runner / Truck’s ECU’s return to battery cable. Sometimes while off-roading the battery can come loose, which can then tug on the ECU’s return to battery cable. If this cable is severed, the truck will not run.
View this How To Guide on soldering if you need any more tips for this part of the guide.
Disconnect the ECU and positive cable by using your 12mm wrench to loosen the bolt on the battery's positive terminal.
Once the cables are disconnected, place the positive cable out of the way.
To reassemble your device, besure to place the positive cable down first. Then place a washer between the cables. Place the last washer on top of the ECU cable, then bolt down.
