Salta al contenuto principale
How to set up a Home Theater System
Cosa ti serve
  1. How to set up a Home Theater System, Part one the Sony Home Theater System: passo 1, immagine 1 di 2 How to set up a Home Theater System, Part one the Sony Home Theater System: passo 1, immagine 2 di 2
    • This is the wireless receiver for the Sony Home Theater System, picture two shows the connections and the wireless card.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to set up a Home Theater System, Back of the Sony Wireless transceiver: passo 2, immagine 1 di 1
    • As you can see the blue and gray plugs are inserted in the blue and gray sockets. The small black dongle is the wireless card.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to set up a Home Theater System, Back of the Sony Home Theater System: passo 3, immagine 1 di 2 How to set up a Home Theater System, Back of the Sony Home Theater System: passo 3, immagine 2 di 2
    • As you can see the red and white connectors need to match, but in my case that was the only color connectors I have, The blue one (red) goes to the right front speaker, the gray one (white) goes to the left front speaker, the purple one goes to the sub woofer, and the green one goes to the center speaker.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to set up a Home Theater System, Speakers used: passo 4, immagine 1 di 3 How to set up a Home Theater System, Speakers used: passo 4, immagine 2 di 3 How to set up a Home Theater System, Speakers used: passo 4, immagine 3 di 3
    • The first speaker is the right front speaker. (There are two of them, one in the left corner of the room, and one in the right corner of the room). The two small speakers in the 2nd and third pictures are the surround sound speakers.
    Chiedi a FixBot
    Aggiungi Commento
    • This basically shows you what you can get in 20 seconds.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Setup is easy, in the next tutorial I will show you how to set up and record records and tapes.
Altre 2 persone hanno completato questa guida.
rcamp48
Membro da: 05/09/19
187 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 64
Tutti i Tempi: 784
